Omron CX Programmer help
kevbloke
Jul 2004
Kent uk
81
Hi all,
For all you Omron experts out there. I was asked to look at a priming issue on some conveyors.Found the problem but wondered what a bit in the program means.
Im a Step7 fella really and wondered if someone could shed some light on a block.
Its got OUTB(534) at the top. Underneath it has D11028 and below that #3.
This is in parallel with an output coil. The coil just starts a motor. I'm intrigued to find out what the block does. I would put a screen shot on but the CX programmer is on a non networked laptop.
Kev
OUTB(534) is used to control bits in DM and EM registers. Look at pages 173 & 174 of the W474 manual (CJ2 instruction reference). If you don't have the manual you can download it from the Omron Europe website.
Hi
There was a good instruction help the last time I used Omron. If I pressed f1 or it was under the help tab ontop . It gave a very good break down and I found it good it was new to me also . I was using cx programmer also
Donnchadh
The quality of the help is really dependent on the model of the PLC. The help for for the current range of PLCs - CJ1 - CJ2 - CP1 & CS1 is very good.
For the older and discontinued PLCs - CQM1 - CPM1 and older has not been updated as they are generally discontinued and replacement parts are not available so the help files have not been updated.
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,596
Hi I have had been running Omron's CX Programmer (ver 6.3) I recently went to use it and check something via the help menu and it crashes out. I...
7,435
Has anyone seen the problem where the print job won't start when using the print utility. I am using Omron's CX-Programmer 1.2 with Windows 2000.
4,668
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
385
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
745
