Can You Help with Omron CX-Programmer Printing Problems
LGropel
Nov 2002
Has anyone seen the problem where the print job won't start when using the print utility. I am using Omron's CX-Programmer 1.2 with Windows 2000.
In the hand position: Pumps 1 and 2 are controlled and alternated by the hand selector switch. When Hand position is first selected, pump 1...
3,594
Hi all, For all you Omron experts out there. I was asked to look at a priming issue on some conveyors.Found the problem but wondered what a bit in...
3,836
Hi I have had been running Omron's CX Programmer (ver 6.3) I recently went to use it and check something via the help menu and it crashes out. I...
7,428
We have an omron CJ2M-CPU12 PLC that we are having issues with an AD04U analog card. it is connected to a K type thermocouple sensor. The card is...
608
Hi all, While i am not new to omron, i'm totally new to the analog part and lost. i have a CJ2M cpu 33. then there are 4 i/o cards card 5 is a...
26
2,589
