Omron EJ1n modular controller
Terry Boblitt
Jan 2006
Willisburg, Ky.
119
I have 12 of theses in 2 racks connected by Devicenet to a Compaq logic processor. One of then isn't acting like the others. I'm getting more deviation. I've been reading the manual---you have to set theses up if one is replaced--right? It's not as simple as setting the dip switch and the node address? I have one of these at the front of the rack EJ1N-HFUB-DRT.
Any help & advice is appreciated.
Thanks Terry
Hello all, I would like to ask how to transfer the temperature reading of OMRON EJ1N temperature controller to the data memory (ex. D100) of...
4,619
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
178
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
67
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
111
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
265
