OMRON CJ1M PLC to EJ1N-TC4 communication
Den Mark
Mar 2009
Cavite
35
Hello all,
I would like to ask how to transfer the temperature reading of OMRON EJ1N temperature controller to the data memory (ex. D100)
of OMRON CJ1M PLC. using CX-thermo, i don't see any parameter that will be the reference of the PLC to the actual read-out out the temperature controller.
hope you can help me.
thanks.
Well, I hope you found your answer sooner than 35 months, but in case anyone else is seeking this . . .
Use CXThermo, connect to the HFU communication card which must be attached to the TC.
in the left pane, navigate to cursor to Communications, Programless Settings.
Programless Communications Parameter Editor.
Set up the desired memory areas which your TC inputs and outputs will use.
Save it into the HFU.
Hi I have a plc omron CJ1M connected to a HMI this is a reconditioned panel in which this plc is connected. But the touch screen of the HMI is not...
3,588
Dear Friends; We have OMRON CJ1M CPU23 with I/O cards at one of our machine. We have arranged a spare PLC and tried to download the program...
6,929
Hi all, I am trying to add a function block to a PLC program written for an Omron CJ1M PLC. However, CX Programmer has thrown a compile error...
5,343
I am a new user of Omron PLC. I am facing trouble while connecting my Laptop (Siemens Field PG)to Omron Sysmac Cj1m CPU22. I am using CX-One...
4,942
Hello to all I want to download the programm from OMRON CP1E plc.I have a USB Transfer cable that work fine with CJ1M plc Although these 2 plcs...
3,819
