PLC Omron CJ1M CPU 22 HMI not working
Mobi1947
Jan 2017
Saudi Arabia
Hi
I have a plc omron CJ1M connected to a HMI this is a reconditioned panel in which this plc is connected. But the touch screen of the HMI is not functional just for few buttons rest all is functional what are the possibilities or the error i should be looking at.I am attaching some pictures for reference.Is it possible for me to get the program from HMI to my pc without connecting the rs232 cable of the PLC and how do i check if the hmi is functional some buttons are working.
Do you have the exact model number of the HMI?
The picture does not show it well on the back of the unit.
Regards,
http://www.omron-pro.ru/doc/automation/panel/ns.pdf
The above is the operation manual for your HMI. It can be programmed through the Port B of the unit using the NS-Designer software.
It appears in the picture that you are currently using Port B as a 'Host Link' connection to the PLC.
Hope this helps to get you started.
Regards,
Thank you for your quick reply i was wondering if i have to use the normal rs232 cable or the omron brand cable
Dear Friends; We have OMRON CJ1M CPU23 with I/O cards at one of our machine. We have arranged a spare PLC and tried to download the program...
6,928
Hi all, I am trying to add a function block to a PLC program written for an Omron CJ1M PLC. However, CX Programmer has thrown a compile error...
5,343
I am a new user of Omron PLC. I am facing trouble while connecting my Laptop (Siemens Field PG)to Omron Sysmac Cj1m CPU22. I am using CX-One...
4,942
Hello to all I want to download the programm from OMRON CP1E plc.I have a USB Transfer cable that work fine with CJ1M plc Although these 2 plcs...
3,819
guys please i bought cpu (cjim-cpu120 with input modules (CJ1W-ID262) and i wrote the whole program but i have a problem with addressing if...
2,868
