omron error.
Jun 2013
Jaipur Rajasthan
18
Dear Friends,
I have a omron PLC CP1E-E40DR-A. PLC was ok and working properly but now ERR/ALM light glow and I can not communicate PLC to my computer.
How can I solve this problem.
Please give me solution...:confused:
Check section 6-1-5 of the W379 (CP1E CPU Unit Hardware) manual. The error you describe is a Fatal CPU Error. You will probably have to contact Omron to resolve it.
Hi, I am facing an error inside Omron Network Configurator. I have 2 PLC communicate each other using ethernet cable, send signal using Network...
147
Hi Everyone I am facing an issue regarding Omron servo drive R88D KN06F ECT. When I try to replace the servo drive on the machine it is stuck on...
313
i have been trying to connect to omron cj1m via peripheral port(USB to Serial), but there isn't any sign to show that it has connected, so am...
330
Hi, I am very much a novice when it comes to PLC's I have only ever had to change the IP address on them, and go off notes left by a previous...
1,008
Has anyone encountered an error code 31 on an omron cj1m-cpu12? This error code is not covered in PLC manual.
527
