OMRON FINS Gateway/SysmacLink
Shoop
Jun 2002
NL
18
This a question for the OMRON guru's around here.
I have A platform running 4 OMRON PLC's (2 x C1000H and 2 x C200H)
These PLC's communicate with each other via SYSMAC link (and LR bits)
There is also A SCADA PC which communicate's with these PLC's.
It use A FINS gateway Card and via this card it can communicate over SYSMAC link with the PLC's to get it's info.
There is also a Programming PC to change code's in the PLC's, It also use A FINS gateway Card and via this card it can communicate over SYSMAC link with the PLC's to change the code's.
Now I have the problem the when I change code (online) in PLC 2 (this is a C200H) the SCADA PC looses it's communication and it doesnt come back until I restart it's Database.
Doing a online change in one of the other PLC's does not Give this problem.
Is there someone with a similar problem out there?
Thanks already
hello everybody i want to download fins gateway v3 but i didn't know ... i searched in several website but i didn't get any information ...
1,856
Hello, someone have an example of an comunication between an Omron CJ2M CPU33 with FINS TCP to PC? Thanks for help
1,404
Hello people Has anyone managed to perform an arduino communication with an omron PLC through the FINS TCP/IP protocol? I already managed to do...
2,201
Hello Someone know an Function Block or example code for Fins TCP/IP or UDP working for CJ2M CPU33? Thanks for help
1,231
Hi Guys, a few years ago I started to write a little test program for PC to communicate with OMRON PLCs by FINS commands. Well, I would swear...
2,831
