Omron Internal Fuse
Bob O
May 2003
1,873
We have a piece of equipment with an Omron Model 3G2A5-PRO13E/3G2A6-PRO15E SYSMAC-C Series PLC.
I am not getting 24 VDC out from the power supply on the PLC. I don't have the manual for this or any Omron PLC. The machine runs fine with an external power supply hooked up.
Is there and internal fuse for the 24 VDC power supply?
Thanks,
Bob
So I have a program for an Omron CJ1M PLC that I have to reverse engineer for a customer. This PLC is meant to control a water pump station...
1,844
Hello, friends.. I made a post over at MrPLC.net and I didn't get an answer so here I am.. I'm just gonna copy my post over here : First thing...
17
3,938
Hi evrebody,I never work with Omron PLC but I get a project with ck40.Using syswin4.3 I could not find how to put the internal relay in...
3,412
The Omron PLC CPM 2A-60 has a small glitch. When all the permissives are satisfied the long timer won't time down. When the timer bit is forced...
2,911
I am a robot technician at work where we use mostly Omron PLC's. About 8 years ago I took a course on PLC's (Texas Instruments). We used a DOS...
7,723
