Reading internal address -- Omron C1PL-L
I not have any experience using this address 50.
it looks everybody can upload/download the plc,
On your statement during uploading actually downloading the PLC setting.
After download you need restart the PLC by power down for PLC to take effect.
present the HSC not active
request shut down for download the PLC setting.(if you program not alter)
better upload first and compare with your document
if you want to simulate high or low frequency on display it's not meaning anything.
Better you use PULSE injector to your PLC input it more better approach
We have a SCR in our system to redirect the paddle wheel count to the high speed input of the PLC.. when we test we usually pulse 24vdc directly on the SCR to see if we have something coming in the PLC (input 00 in my case). I want to eliminate this process with what I explained above !
156
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
106
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
233
Dear all, I don't know why setup of password became challenging and weird. After setting up the password and try to upload the ladder from the plc...
178
