omron memory card for plc
irondesk40
Jan 2008
nc
630
have a question about the omron plc and the memory card.
If i understand correctly you can take the program that is in a plc and if you have a memory card installed in the plc, you can select to back the program up on the memory card, and then if needed set some switches on the plc and reload the contents of memory card into the plc.
Would anyone have a pdf file that would explain this in more detail.
We have used the micrologix 1200 on the last couple of projects but like the fact that the omron has the memory card option.
Also with some of the older omron plc's that we have used such as the cqm1 plc you could save the data memory area, hr area etc in seperate files. Can these also be saved on the memory card and reloaded if needed, as well as the plc configuration and configurations for cards such as analog cards, ethernet cards etc.
thanks
The CS1 and CJ1 processor families have on board Compact Flash slot. What you are describing is the Easy Backup Feature.
Take a look at the information for Dip Switch 7 on the attached pdf. Note this is a page form the W393 manual for the CJ1.
This feature will backup all memory areas, I/O table, Special I/O setup, basically everything that would need to be reloaded or restored to a new unit.
Hope this will help.
Hi All, I have an Omron PLC program which is copied from the memory card. Could you please tell can I open the PLC program using CX programmer or...
959
Omron's CJ2M has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be loaded...
3,035
Omron's CPM2A has a compact flash card slot. Can an Omron program simply be copied to a compact flash card using a Card Reader or must it be...
1,524
Hi All, as in the title I'd like to check with you some thoughts I have regarding the Omron Memory Card option offered with the CJ2M series PLC...
4,581
good day all i have a problem about my omron cqm1h all program was lost. they gave me a memory card module then i load it but there is no...
2,914
