Omron memory mudule???
mordred
Mar 2004
Red Deer
1,892
Trying to learn Omron programming having worked with AB for about 5 years. I just need to clarify the distinction of the various memory areas. If my understanding is correct the work area is the same as the holding area except the holding area is retentive?(holds last state until rewritten).
How does the temporary relay area work?
does anyone hsve a good link that has a better explanation that the instruction set manual?
You are correct.
Unless you are programming with the handheld console, temporary relays are transparent to the user. They are used similarly to the branch end function in SLC 500 instruction set. The software will assign them for you and unless you view the code in mnemonics, you will never see them.
Thanks Jay tha tpretty much answers my immediat questions now to put what I've learned into practicum.
Project involves updating a ~23 year old controller (C200HX CPU64). The HMI is a windows NT machine with the gui done with Delphi 5 (Pascal)...
1,120
Hi All, I'm going to start with that I'm new to Omron and this is the first time I'm dealing with an Omron PLC. I have a project...
1,984
Hi All, I have an Omron PLC program which is copied from the memory card. Could you please tell can I open the PLC program using CX programmer or...
961
Hello, I want to understand the memory mapping of a CPE1 Omron PLC. Which areas are accessible and generally operate like a flag bit. Second...
2,141
Hi everybody. On omron plc cpu20 ihave constant memory err After bettery drain and plc got out of power i removed all errors with pro15 but i cant...
1,185
