omron plc cpu20 memory err
johntba
May 2018
greece
Hi everybody.
On omron plc cpu20 ihave constant memory err
After bettery drain and plc got out of power i removed all errors with pro15 but i cant find program in ram .all lines in pro15 are with ???? .This mean program lost?Is there any way to restore it or recover?
thank you in advance
It sounds like you have a C20K or C20 series Omron controller. The full part number should be printed on the top or side of the PLC.
Yes, your program is lost.
The only way to restore it is to reload from a paper copy or backup if you have it.
You will have to replace the battery, or your program will not be saved in the ram memory.
These controllers also have the ability of an EPROM. This is located under a hatch on the top of the CPU. If the socket is not empty, there is a chance the program might be on it.
https://accautomation.ca/omron-c20k-c28k-c40k-c60k-troubleshooting/
https://accautomation.ca/purchase-find-parts/omron-c20k-c28k-c40k-c60k/
Regards,
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
146
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
125
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
193
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
117
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
229
