Omron NP and Mitsubishi Melsec-A
desuhardi
Oct 2005
Indonesia
46
Hello,
I've problem with connection between Omron touch screen NP5 and Mitsubishi Melsec-A, use its programming port.
Cable connection is correct, according to manual. Use RS422 with 9600, 8, Odd, 1 (COM2 on NP series). Dip switches set on NP are correct.
But still can't communicate between them, host PLC error.
Is there any setting must be consider ?
Thank you
Hi Guys, I am trying to read data from Omron CP2E CPU from my Mitsubishi RJ71EN71 with Simple CPU Communication Function. Suppose it was using...
1,814
Hi, In a project I have four Progressive Pressing Machine. Each machine with different PLC like Mitsubishi 'Q00UCPU' with...
3,046
Dear sir, I need to connect my encoder with mitsubishi PLC and take the encorder values to plc . My item specifications are as below. PLC is Q...
3,770
Hello, I have programmed AB (SLC and micro) at previous companies. I am venturing into my own business. For cost and 'breadth' of skill-set, I...
5,916
Hello All, I want to make cable connection between Omron NP screen and Mitsubishi FX2N CPU (programming port). If somebody know about this...
2,062
