Omron OPC driver for Cimplicity
Ianc
Sep 2004
Has anyone any experience of using OPC to talk ethernet to Omron PLC's from GE Cimplicity software? I would prefer not to go the FINS gateway route if you have any other suggestions.
I'm try to use "CX-Server OPC" v1.0 with Intellution iFix 3.0. It really work but have some troubles (stop working with high PC CPU loading, disabling i/o points data exchange, strange timestamp values and etc.) These errors are coming up because "CX-Server OPC" of discrepancy to OPC foundation standards.
Hello Bodis,
If you're using v1.0 of CX-Server OPC, then yes, you probably will have some problems. (Isn't this the case with any software marked version 1.0 ???).
I can categorically state that v1.21 is completely OPC compliant (to standard D.A. ver 2).
I suggest you contact your local rep for an upgrade - this should help with any problems you may be having.
My local OMRON representative didn't recommend use "CX-Server OPC" to us in general. As replacement hi has offered using SCADA "CX-Supervisor"
Thanks for the help, after some further digging it would appear if i buy the Cimplicity Pro version i will get the GE drivers for Omron bundled with it . Hopefully if there are any issues there will only be GE to deal with then.
If any one is screaming "no don't do it" please let me know!
Hi, In a project I have four Progressive Pressing Machine. Each machine with different PLC like Mitsubishi 'Q00UCPU' with...
3,040
HELLO all I have an appliaction relying on variables which are tags from sysmac opc server/ I however need to create my own application but still...
1,556
Hello, I have added an OPC server (Kepserver) to a PC which is connected to 3 Omron (CJ1) PLC's via FINS Ethernet. The issue I am having is that...
1,841
We have a few Omron NJ301-1100 processors and am attempting to connect them to a KepServerEX OPC server. I am able to establish good...
2,180
Hello, Does anyone has some experience with an opc server to an OMRON CP1E plc? This plc has a USB programming port and a serial port to connect...
5,545
