Omron PLC & Red Lion HMI.
Elcan
Apr 2008
NC
935
Hi all,
I wanted to know if somebody here has experience communicating a Red Lion G308 HMI with a Omron CP1H-XA40DR-A (or similar) using the Ethernet adapter CP1W-ETN01-US, or without using this Ethernet adapter.
Thank you!
I have tried the CJ1 using fins to the redlion g310 without success. I had to resort to 485 comms between the devices with a moxa 485/232 auto baud converter at the PLC side.
It was a blessing though, as I managed to configure the PLC on the factory network and can now go online to it from my office.
To lostcontrol
The CP1W-ETN01-US is a US product. It was designed prior to the CP1W-CIF41 being offered. It is an Ethernet device.
There is also a CP1W-EIP01-US is an E/IP slave unit.
Hope this will help.
Not directly, but cannot imagine it would be that difficult.
Are you experiencing issues?
No, I'm still in the design phase. This will be my first Omron PLC.
I was assuming I would be able to easily communicate this PLC with the Red Lion HMI, but I wanted to check.
Red Lion said that, if the PLC/Ethernet adapter uses FINS, it wouldn't be a problem, but I wanted to hear it from somebody who has experience with the Omron CP1H / Red Lion combo.
Hi, First post, I am new to this forum. I tried searching with no luck. I am using an Omron PLC - CJ2M CPU32,and I am trying to get it to...
2,398
Hi all, I only do PLC Programming on and off and have never done programming analog stuff therefor I need a pointer in the right direction. We...
4,616
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
67
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
170
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
135
