Omron PLC's
boiler-todd
Nov 2003
Layton, UT
47
I have programmed a few AB machines, but never Omron. Most textbooks I have seen typically illustrate AB ladder logic. Are there any reference materials for programming Omron? I transferred to anoher plant that uses both AB and Omron, so now I need to figure out Omron.
Thanks,
Todd.
Thanks,
Todd.
Hello Todd,
If you expected to use Omron kit, then I'll assume that your organisation has a copy(ies) of CX-One.
If so, under the START menu for CX-One, there should be an "Introduction Guide Library" which contains several "quick start" type guides.
You may find these useful.
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
60
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
167
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
134
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
196
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
124
