Omron Program corrupt? from CQM1H cpu21
Ron Macam
Dec 2009
Manila
Attach is the program that i uploaded from the PLC after it got underwater from typhoon. Can anyone verify if its corrupted and can't be recovered? Its a depalitizer program.
What you are seeing is the comms protocol (usually occurs with the USB -> serial comvertor). You are using the wrong comms port. Check which USB port becomes active under your PC's device manager and set the port used in CX to that.
well considering I cannot get it to show as ladder except on the NOP rungs and all the rungs without NOP are red on the left I would say its a good bet its corrupted you may be able to redo this this by prining it off then converting it but hopefully you have the source code or a copy of it
well your in luck for each line in red
on the rung column copy the the statements then delete the rung
add the rung back into the same position then paste the nmemonic statement back to it I did 5 rungs that were in red and was able to restore them
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
175
Hi Everyone, I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online...
360
Hello everyone, We have a PLC Omron CJ2m CPU12, it contains an old program and it is UM read protected by password. Now we have a new program...
538
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
889
Hi all, Normally I would try to research this more before asking this, but I am under a tight schedule of changing computers. I have a bunch of...
1,437
