omron software upgrade
irondesk40
Jan 2008
nc
630
just renewed our contract to get the latest version of cxone.
The version of cx programmer that I use, which is version 6.3
We have dozens of production machines that I have modified or created with this version of cx programmer.
Once I get my new copy of cxone, the cx programmer will be a new version.
If I modify or create a program using the newer version will the technicians in some of plants who are still using the older version of cx programmer until we can get everyone upgraded be able to open the file?
It should not be a problem.
Pretty sure the file format is the same.
The difference is mostly support for new processors.
Some usability enhancements.
Hope this will help.
I think problems may arise if you use IEC structured-text function blocks and programs which older versions of CX-Programmer may not be able to read.
Does anyone else have an issue downloading from their Automatic updater? I typically get around 1MB/sec this is running around 70kb/sec. Is...
3,352
Hi all, i have started a new chapter in my career with a local company. a lot of their plc's is omron and i have the cx version 9.75 software...
25
4,235
Hello, Do you know if the CX-One 30-day trial version will allow me to obtain diagnostics from the CJ2M PLC? I don't need to program anything...
1,334
I have a machine with an Omron Sysmac CQM1 PLC & NT20S HMI. I got the NT software installed on a VM & the OEM files, it opens OK. I also have...
2,453
Questions i hope folks on here can assist with. It has been my experience that Rockwell Software will not run and work correctly if you do not...
2,567
