Omron SYSMAC C40k Eprom option
aju79
Feb 2008
Karachi
I have Omron Sysmac C40k programmable controller... I want to program it but i dont have programed eprom and Host link unit.. But I have Syswin V3.4 Software. In Syswin there is an option "Save Eprom Image"... But this function is not active with the selection of CxxK PC... If I select any other PC like CQM1 then it becomes enable...
HOW CAN I GENERATE *.BIN FILE FOR C40K Programmable Controller FROM SYSWIN V3.4... OR
Can anybody help me How can i program C40k with out Host Link Unit, Any other Omron PLC and Programed Eprom...
Waiting for Reply..
I agree with Bob on this one, It is too old to be worth saving.
Also to program an EEPROM you will need a prom writer for the C40K, this plugs into the large programming port slot on the front of the CPU. First you download the program to the CPU then upload to the EEPROM. I'm fairly certain you cannot purchase the prom writer anymore (and if you could it is probably more expensive than a whole new PLC).
If you have Cx-Programmer - get a CP1L
If all you have is Syswin - get a CPM2A
Eitherway you will be better off.
Omron c40k not in RUN mode
Dear friends,
I have a Omron c40k controller , it is coming in RUN mode what is the solution to this problem.
Dear friends,
welcome to the site
Mate, if it was working then it is probably now dead.
this PLC is very very old.
1. Are there any error lights?
2. is the programmer plugged In? - unplug it and then power down then UP
Dear Iant,
1. There is no ERROR or ALARM light is there.
2. It is not connected to a programmer , actually i don't have a programmer .
WHAT NEXT?
I am sorry but the only help I can give you is to recomend you replace the PLC. it is just too old
I am trying to get info on an omron sysmac c40k. The plc works, but 2 of the inputs are shorted and i would like to just move the inputs to an...
1,973
We've got the Omron Sysmac C40K in a few of our machines at work, one of them started to behave bad and gave up. Power LED on and input LEDs work...
9,855
Hi evrebody! I have old OMRON SYSMAC C40K with progamming console .Is any way to connect it to the loptop and what I need for it? This PLC was...
6,252
I took an online course but don't remember covering this. How do I access the system clock in a compare instruction? I want to turn on an output...
512
I come from an AB background. My current job has a lot of Omron devices. We have a couple systems with NX102's with numerous IO link devices...
660
