Omron tag data link error detection
balazs.jakli
Dec 2022
Budapest
Dear colleagues,
I've made a couple of projects with Omron PLCs, still, I can't figure out a quick solution to this one.
I have a CJ2M-CPU32, which is talking to a robot, and a pneumatic valve block through Ethernet/IP connections. Connections made in the Network Configurator. All working well.
I need to implement some safeguard reactions when the connection is broken with either the robot or the valve block. I need to see the errors in *registers* when they happen.
There is no HMI in this setup.
If I disconnect the network from one of the devices, the 7 segment display shows the D5/D6/D9 errors, but I can't find them in A300, A100-A199 and other locations.
I hope somebody can point me in the right direction.
Thanks,
Balazs
Hey guys. I recently added a barcode scanner to our network. I can see the device through network configurator. When trying to set up the tag...
1,637
I am using a function block that has a in/out parameter that is a structure. The structure has an array as one of the elements. I can index the...
757
Can anyone explain to me how to link a bit in one PLC to a bit in another PLC?
1,540
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
31
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
70
