Omron XFER command
automatic
Aug 2004
136
Why doesn't this work? I am trying to run the XFER command on a CS1 and it's not transferring the data. The PLC is in RUN mode.
Does anyone know how to exchange data between an Omron and GE PLC using TCP/IP???
1,966
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
180
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
72
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
112
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
268
