OMX rs232 control interface and compact logix plc
sruthi
Jun 2010
Hyderabad
I have an OMX RS 232 control interface unit which needs to be interfaced to Compact logix plc using rs232 communication protocol. I need to read the values into PLC from field using the OMX interface unit. values like temperature and RH are to be read.Once i pass some message instruction/string into OMX unit it should be able to read that and give me back the information from field. But the dont know whether the the information which we get back into PLC is a message instuction or a string..!!
Am attaching a copy of OMX unit.Kindly let me know how can do this interface ? what should i set in the PLC and how do i read the values from field.?
pls help me out..
Well... That brochure helps not at all. No protocol, no encoding, no command information.
But, it doesn't use MSG instructions, I'll tell you that much.
Use the ASCII read and write instructions, and PARSE the return string manually.
Strangely, there are even (basic) examples in the "Instruction Help" part of RSLogix 5000 software under 'ARL', 'ACB', 'AWT', well, ALL of the Serial Port Read/write instructions.
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
99
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
240
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
732
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,563
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
387
