Online Editing with RSLogix500 disappeared
plcman777
Oct 2004
Wa.
25
I lost my ability to do online edits to my SLC5/04.
I did online edits for three days in a row, then on the fourth I was no longer able to do online edits.
I checked all the places I could find in the help files to enable online edits and they are enabled.
Any ideas why suddenly I no longer have the option to online edit?
I think you may have leftover edits from previous online sessions. Make sure to assemble or cancel past edits before editing again.
there is a BIT in the S2 file somewhere that needs to either be set or reset to enable online editing. It should not have changed for u, but u never know?
There are two bits (S:33/11 and /12) that indicate whether online edits are present, but I am not aware of a settable bit that prevents online editing. (but I have still not seen everything !)
I wonder if RSLogix 500 suddenly thinks it is the Starter edition ?
Are the edit buttons simply no longer present, or are they greyed out, or is there some other symptom ?
Thanks for all the suggestions. Here's what happened.
I figured out that I rushed out of the program without finishing an edit, to go to another problem elsewhere.
Then when I returned I made offline changes and downloaded the program.
That caused RSLogix to say that I still had Edits Active but I could not accept, test or assemble them because I had downloaded a new revision.
I cured the problem by pulling the battery and shorting VBB to GND and downloading the program into a blank processor.
Problem Solved, thanks.
Hello everyone. Is the PLC CJ1M CPU13 capable of online editing? Or only downloads that will stop the PLC? Thank you.
348
Hi all, Does anyone know if WAGO 750-8100 with e!****pit supports online editing? Thank you.
723
I have been asked to extensively modify a piece of machinery that is very mission critical to the operation, thus not allowed much downtime or...
2,299
In the last two months I have had an issue after making some online changes between the software and an Schneider M221 PLC via ethernet network...
1,101
I was wondering, is possible to remove IO_AIN and replace the instruction with another one without getting offline in RS Logix 5000
2,007
