online remote rack changes with ethernet
phinix
May 2006
l.a
33
hi u all
i am looking for a vendor how can provide a full system like Siemens pcs7 , but
that can allow on-line changes to to the remote io racks (card change , rack adding , card adding ...) with one of the Ethernet industrial protocols to the remote racks .
as i understood with Siemens it is possible only using profibus-dp
thx (y)
Ethernet/IP is fast, reliable when you follow the best practices guidelines. You can add some type of I/O while online, but not all types. I beleive its restricted to 1756 I/O, racks, cards and PF Drives on Ethernet/IP. I don't know much about Siemens, but I don't think Rockwell has a mini-DCS system as one product. But I think you could put together something like a mini-DCS using several RA products though.
PlantPAX is RA's answer to DCS. I have no experience with it and based on my experience with another vendor's "mini-DCS" years ago, I would be very careful about adopting it.
thx Harryting
i would very much appreciate if u could elaborate some more concerning the heads up for adopting the mini-DCS
PlantPax is the software routines for ContolLogix and FTView SE. It gives you the add-on instructions and SE faceplates to make a nice system. It gives you a great head start as all the routines have already been tested.
Good Morning , I need to make a online change to a SLC 500 5/05 . Is it safe to turn the key from Run to Remote with causing the processor...
1,881
Dear all, I am facing an issue at site on a Process PLC (PLC-5) while trying to add 4 new AI channels for Flow Meters. Location is South Sanha...
8,776
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
121
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
84
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
250
