Online RS Logix500
TheVo
Jun 2005
Ho Chi Minh City
24
Hi evryone
I have a problem with RS logix 500.
When I open the old program and online to PLC, I choose "upload using file" but when online I lost all commemt and symbol.
Do you know why is it?
Phung
RSLogix500 only looks in a default directory for your RSLogix projects. So when you attempt to go online and it doesn't find the "right" project, many people mistakenly choose to create a new project. Creating a new file uploads the contents from the PLC but since the comments are not in the PLC, they will not be available. This project gets saved to that default directory and then later, when you try to go online you use the "Upload using" option, but it is uploading the logic into this project that has no comments.
Creating a new file is a common mistake people make. They then think they have "lost" their comments. Their comments are typically still there, just in another directory on their PC. Use windows search to find all .RSS files and you will probably find it.
If your project is stored in a specific location, then go find it and then open the file before you attempt to go online.
OG
another possibility is that the .RSS file you are "using" actually IS the best file – BUT – maybe that file doesn't have the comments and other documentation stored in it ...
this happens when someone "creates a new file" to go online (as in an emergency situation) and then "saves" the file when they shut down ... in this case, the file now stored on the disk is "empty" of documentation ...
suggestion: open up any "BAK" (backup) .RSS files that you can find for your project ... (in most cases there are three of these saved in your default directory - the highest number should be the most recent) ... maybe you'll find the documentation in one of those ...
and one other long shot ... check under View / Properties / Comment Display and make sure that the software is actually set up to show the documentation ... that dog's bitten a few people in the past ...
Export & Import
commemt and symbol can be export from the any old file, then import to the newly uploaded logic file.
export it to the folder where the new upload is.
or any folder you wanted, as long as you can find it when importing it.
I am very new to AB PLC's we have a ML1200(14 inputs/10 outputs B series) we are trying to connect it with RSLogix500 (4.50) software thro RSLinx...
2,699
When using RSLogis500 to connect to SLC PLC , some project can't see the comments when online. Why?
3,432
Hello, is it possible to view the cross reference list while online? I can click on the inputs/ outputs etc. on the left hand side and scroll the...
2,238
I lost my ability to do online edits to my SLC5/04. I did online edits for three days in a row, then on the fourth I was no longer able to do...
10,812
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
98
