Online through PLC to Panelview
rigicon
Aug 2009
kent
415
Hello Plc experts,
I have an Allen Bradley Panelview Plus 600 (2711P-K6C20D) connected to a Compact logix L35E(logix 5335E 1769-L35E ethernet serial) PLC. They talk to each other through a router(hub,switch). I go online via ethernet very fast.
I recently put a modem on the PLC serial port and can remotely go online slow but it is ok for small changes or diagnosis. I was wondering if I could talk through the modem and through the serial PLC port to the Panelview. Having written that I have confused myself as the panelview is ethernet connected to the PLC. Am I being silly is this not possible?
Download to Panelview via PLC
Hello Plc experts,
Can it be done?
Over ethernet you are communicating directly to the screen, not through the PLC to the screen.
For your proposal to work on the serial port, you would need to communicate to the screen through the PLC with a software that is not capable of communicating to the PLC?!?!?
I have no data to back this up, but my answer would be "no".
Hello, I have a S7-300 PLC I want to get online with and take an upload of the prog. I have a laptop with the correct software and USB adapter...
1,558
I have arranged a spare PLC5 for our machine which already has PLC5. After receiving, I set the dip switch settings same like the original...
5,089
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
153
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
89
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
278
