Online with M340 and SCADA
bisk
Jul 2008
toronto
20
The M340 processor has a Ethernet port for witch to go online with, my question is, I need the processor to be connected to SCADA at the same time that I am online with it. How would I accomplish this if there is only one Ethernet port? Could I use a switch or router? I would appreciate if someone could explain how I would accomplish this.
Thanks!
With an Ethernet switch connecting all devices, you should be all set.
Ethernet is inherently multi-master and multi-slave (old terminology) or multi-client and multi-server (network terminology). In your case the M340 processor port is the server, and can handle multiple ModbusTCP clients (as well as http, SNMP, etc. clients).
As long as you don't hit the capacity limits - point both SCADA and UNITY tools to the M340 port by IP address and you should be OK.
Hello, I have a problem with one of my program in Unity Pro for a M340 (model 342020). When I make online modifications and generate it, the...
3,172
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
103
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
83
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
248
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
409
