OP 270 winCC flexible
Egyaim
Feb 2004
Accra
Hi guys
I have a problem with OP 270 panel we recently received
is not able to keep parameters .
we are using profibus connection to S7 315 cpu
any time you switch off the panel it changes to MPI
can someone help me?
Yes, I always have to change from MPI to Profibus in the window CE control panel
S7-Transfer settings.
If I remember correctly the transfer settings button has a tiny "OK" button in the Caption Bar (just left of the "close" button). To save the settings use this button, not the close button.
Connection between the OP270 and S7-315 is set up in WinCCFlex, NOT on the OP. If it is selected Profibus in WinCCFlex then it'll use Profibus.
The only thing that can be changed using the 'S7-Transfer Settings' are bus speed, bus address and if OP270 is master on bus, it does not select which protocol to use.
Please state the problem you encounter a bit more precise.
Jeebs
Guys I have one TP270. early it was programmed in Protool software.But i don't have the backup in protool format or protool software. I have...
3,240
Hello, I'm programming a TP270 with many buttons. But now i want to have a pop up with "Are you sure, Yes, No", or something like that, evertime...
4,099
Hi there, I have a TP270-10" Screen that I cannot download to from WinCC Flex 2008... When in transfer mode, the TP270 has "Loader B 6.0.2.23" and...
8,482
Does anybody know where I could get some training on an FCP270 system? ideally in the UK? Equally, where there is any reference manuals online?
1,001
Dear All, Please help me out I was able to back up using prosave v7.1 but when I was about to restore cannot establish communication. I am using...
24
3,974
