OPC DA Communication
nandgate
Nov 2012
Hyderabad
Dear Friends,
I am using MS Visual Studio 2010 for creating a OPC DA Client (VB).
i have written the following code for connection/ disconnection of OPC Server
'Connect
Try
ConnectedOPCServer = New OPCAutomation.OPCServer
ConnectedOPCServer.Connect("OPC.SimaticNet.1")
Connect.Enabled = False
Disconnect.Enabled = True
MessageBox.Show("OPC Server is Connected")
Catch ex As Exception
ConnectedOPCServer = Nothing
MessageBox.Show("OPC server connect failed: " + ex.Message, "Exception", MessageBoxButtons.OK)
End Try
Try
ConnectedOPCServer.OPCGroups.DefaultGroupIsActive = True
ConnectedOPCServer.OPCGroups.DefaultGroupDeadband = 0
ConnectedGroup = ConnectedOPCServer.OPCGroups.Add("A")
ConnectedGroup.UpdateRate = 10
ConnectedGroup.IsSubscribed = True
MessageBox.Show("OPC server add group failed: " + ex.Message, "Exception", MessageBoxButtons.OK)
End Try
'Disconnect
If Not ConnectedGroup Is Nothing Then
Try
ConnectedOPCServer.OPCGroups.Remove("A")
MessageBox.Show("OPC server remove group failed: " + ex.Message, "Exception", MessageBoxButtons.OK)
Finally
ConnectedGroup = Nothing
End Try
End If
If Not ConnectedOPCServer Is Nothing Then
Try
ConnectedOPCServer.Disconnect()
Connect.Enabled = True
Disconnect.Enabled = False
MessageBox.Show("OPC Server is disconnected")
MessageBox.Show("OPC server disconnect failed: " + ex.Message, "Exception", MessageBoxButtons.OK)
Finally
End Try
End If
So far there are no problems with this code. Can anyone guide me with Data Read/Write Code ??
Sorry for my bad English
With Regards,
NandGate.
Hello,
Here is a sample that uses the automation interface. I have never written one in VB that uses the custom interfaces.
Imports OPCAutomation
'you must have the OPC DA Automation wrapper has a reference.
Public Class Form1
Const itemCount = 6
Dim WithEvents opc_Server As OPCServer
Dim opc_Groups As OPCGroups
Dim WithEvents opc_Group As OPCGroup
Dim clientHandles(itemCount) As Integer
Dim opc_items(itemCount) As OPCItem
Private Sub ConnectBtn_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ConnectBtn.Click
opc_Server = New OPCServer()
If opc_Server Is Nothing Then
MsgBox("Server not created", vbCritical, "")
Exit Sub
End If
opc_Server.Connect("MODOPC.DA2")
MsgBox("OPC server connection failed", vbCritical, "")
Exit Sub
End If
ConnectedLbl.Visible = True
ConnectedLbl.Update()
'add the group
opc_Groups = opc_Server.OPCGroups
opc_Group = opc_Groups.Add("Group_1")
opc_Group.IsActive = True
'create the items
opc_items(0) = opc_Group.OPCItems.AddItem("Port_1.400001", clientHandles(0))
opc_items(1) = opc_Group.OPCItems.AddItem("Port_1.400002", clientHandles(1))
opc_items(2) = opc_Group.OPCItems.AddItem("Port_1.400003", clientHandles(2))
opc_items(3) = opc_Group.OPCItems.AddItem("Port_1.400004", clientHandles(3))
opc_items(4) = opc_Group.OPCItems.AddItem("Port_1.400005", clientHandles(4))
opc_items(5) = opc_Group.OPCItems.AddItem("Port_1.100001", clientHandles(5))
ReadTimer_Tick(sender, e) 'we can start reading
End Sub
Private Sub DisconnectBtn_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles DisconnectBtn.Click
ConnectedLbl.Visible = False
If opc_Server Is Nothing Then 'safety
Exit Sub
End If
opc_Server.OPCGroups.RemoveAll() 'free all the items and groups
opc_Server.Disconnect() 'disconnect from the OPC Server
opc_Server = Nothing
End Sub
Private Sub ReadTimer_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ReadTimer.Tick
Dim i As Integer
Dim ServerHandles As Array = Array.CreateInstance(GetType(Int32), itemCount) 'item ID (server side)
Dim Values As Array = Array.CreateInstance(GetType(Object), itemCount) 'return values
Dim Errors As Array = Array.CreateInstance(GetType(Int32), itemCount)
Dim Qual As Array = Array.CreateInstance(GetType(Object), itemCount)
Dim TimeValue As Array = Array.CreateInstance(GetType(Object), itemCount)
Try
ReadTimer.Enabled() = False
Exit Sub
End If
If Not (opc_Server.ServerState = OPCServerState.OPCRunning) Then 'safety
Exit Sub
End If
'set up which items to be read
For i = 0 To itemCount - 1
ServerHandles(i) = opc_items(i).ServerHandle
Next i
'Try
opc_Group.SyncRead(OPCDataSource.OPCCache, 5, ServerHandles, Values, Errors, Qual, TimeValue)
'Catch ex As Exception
'End Try
Label1.Text = Values(1)
Label1.Update()
Label2.Text = Values(2)
Label2.Update()
Label3.Text = Values(3)
Label3.Update()
Label4.Text = Values(4)
Label4.Update()
Label5.Text = Values(5)
Label5.Update()
' Label6.Text = Values(5)
' Label6.Update()
'There seems to be some issue with zero based arrays and one based arrays.
'I added 6 items with success but I cannot read the six items.
'As you see label1 is using values(1), it should be values(0). I am not a VB
'programmer so I do not know what is going on.
Finally
ReadTimer.Enabled() = True
End Try
End Sub
End Class
Dude,
Thank you very much for the code.
I am able to run the program without any run time errors.
Tomorrow i am gonna check the functioning of the code when it is physically connected to a PLC.🤞🏻
Thanks and regards,
Nandgate
If I remember correctly, all the arrays returned by OPCAutomation are 1-based. That was OK for VB6, where one could choose between 0 and 1-based arrays, but causes additional complications in VB.NET where all arrays are 0-based.
Dear Guys,
whenever i try increasing the itemcount value i am getting errors in runtime. Why is it happening?? and i am not able to read item '0' value. Any Specific reasons for this??
Also Please share the code for writing data to PLC.
Hello,
Telling us you are getting an error without telling us the error type/kind/code/message does not allow much help. Plus on what line does the error occur?
>...read item '0' value.
Read the comment at the end.
I have solved all the other problems, Only "write data to PLC (Sync Write)" code is still troubling me. Please help me out with that.
The final code looks something like this
Public Class Ayyagari
Const itemCount = 16
Dim Errorintimer
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
End Sub
Private Sub Connect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Connect.Click
Try
Exit Sub
End If
opc_Server.Connect("OPC.SimaticNet.1")
Exit Sub
End If
'add the group
opc_Group = opc_Groups.Add("A")
'create the items
opc_items(0) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB0", clientHandles(0))
opc_items(1) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB0", clientHandles(1))
opc_items(2) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB1", clientHandles(2))
opc_items(3) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB2", clientHandles(3))
opc_items(4) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB3", clientHandles(4))
opc_items(5) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]C0", clientHandles(5))
opc_items(6) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]C1", clientHandles(6))
opc_items(7) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB4", clientHandles(7))
opc_items(8) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB5", clientHandles(8))
opc_items(9) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB6", clientHandles(9))
opc_items(10) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB7", clientHandles(10))
opc_items(11) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB8", clientHandles(11))
opc_items(12) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB9", clientHandles(12))
opc_items(13) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB10", clientHandles(13))
opc_items(14) = opc_Group.OPCItems.AddItem("S7:[S7 connection_1]MB11", clientHandles(14))
If Errorintimer = False Then
Timer1_Tick(sender, e) 'we can start reading
Else
MessageBox.Show("Something is Wrong with the Code")
End If
MessageBox.Show("OPC Connection failed")
End Try
End Sub
Private Sub Disconnect_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Disconnect.Click
Try
Exit Sub
End If
MessageBox.Show("OPC server has been Disconnected")
MessageBox.Show("OPC Disconnection failed")
End Try
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
Dim i As Integer
Dim a(5) As Array
Try
Timer1.Enabled() = False
Exit Sub
End If
Exit Sub
End If
Try
For i = 0 To 14
Next i
MessageBox.Show("server handle code has some problem")
Errorintimer = 1
Timer1.Enabled = False
End Try
Try
opc_Group.SyncRead(OPCDataSource.OPCCache, 14, ServerHandles, Values, Errors, Qual, TimeValue)
For i = 1 To 14
Me.Controls("TextBox" & i).Text = Values(i)
Next
For i = 15 To 28
Me.Controls("TextBox" & i).Text = Qual(i - 14)
Next
MessageBox.Show("Sync read failed")
Errorintimer = 1
End Try
' Label6.Update()
Finally
Timer1.Enabled() = True
Else
End If
End Try
End Sub
End Class
Hello,
I have never created a write example in VB but, I did for Excel. It should be similar.
Private Sub WriteBtn_Click()
Dim ServerHandles(36) As Long 'item ID (server side)
Dim Values(36) As Variant 'values
Dim Errors() As Long
Dim i As Integer
If OPCServer1 Is Nothing Then 'safety
Exit Sub
End If
If Not (OPCServer1.ServerState = OPCServerState.OPCRunning) Then 'safety
Exit Sub
End If
'set up which items to be write
For i = 1 To 36
ServerHandles(i) = MyOPCItems(i).ServerHandle
Next i
'fetch the values from the cells
For i = 1 To 36
Values(i) = Cells(8 + i, 3)
If Values(i) = "" Then
Values(i) = 0
End If
Next i
Call OPCGroup1.SyncWrite(36, ServerHandles, Values, Errors)
End Sub
This is the code i have used for write operation
Exit Sub
End If
Exit Sub
End If
Try
ServerHandles(7) = opc_items(7).ServerHandle
Values(7) = 23
opc_Group.SyncWrite(14, ServerHandles, Values, Errors)
MessageBox.Show("Write Failed")
End Try
Hello,
For me, the image is useless. It is too small and scaling just produces a blob.
For the code: You need to read the spec for SyncWrite and what the parameters are used to communicate. You are telling it to write 14 items and you are passing in arrays that are 36 long.
Might work. NOT TESTED. JUST GUESSING
Dim ServerHandles As Array = Array.CreateInstance(GetType(Int32), 1)
Dim Values As Array = Array.CreateInstance(GetType(Object), 1)
Dim Errors As Array = Array.CreateInstance(GetType(Int32), 1)
Exit Sub
End If
Exit Sub
End If
'set up which items to be written
Try
ServerHandles(1) = opc_items(7).ServerHandle
Values(1) = 23
opc_Group.SyncWrite(1, ServerHandles, Values, Errors)
End Try
Now the code is working Fine.
Special Thanks to Mark for the Support.
If Any body wants the final code of OPC Client, just send me a message. I will fwd it
No value return when read from OPC Cache using opcautomation wrapper
Hi guys,
I'm a dead man now,I'm doing cache read using Interop.opcautomation.dll in c# but never get the values,all have returned to my program is null. OPC Server used in my project is Kepware server.Please I really need help and quick response.My code looks like below:
OPCServer opcServer = new OPCServer();
Array OPCItemIDs = Array.CreateInstance(typeof(string),
Array ItemServerHandles = Array.CreateInstance(typeof(Int32),
Array ItemServerErrors = Array.CreateInstance(typeof(Int32),
Array ClientHandles = Array.CreateInstance(typeof(Int32),
Array RequestedDataTypes = Array.CreateInstance(typeof(Int16),
Array AccessPaths = Array.CreateInstance(typeof(string),
OPCGroup OpcGroupNames;
try
opcServer.Connect("Kepware.KEPServerEX.V5", "");
catch (Exception ex)
throw ex;
//Add tags and OPC group.
//set up the tags
OPCItemIDs.SetValue(pointName, 1);
OpcGroupNames = opcServer.OPCGroups.Add(pointGroup);
OpcGroupNames.DeadBand = 0;
OpcGroupNames.UpdateRate = 1000;
OpcGroupNames.IsSubscribed = true;
OpcGroupNames.IsActive = true;
OpcGroupNames.OPCItems.AddItems(1, ref OPCItemIDs, ref ClientHandles, out ItemServerHandles, out ItemServerErrors, RequestedDataTypes, AccessPaths);
//Read the values from the server for those tags.
Array ItemServerReadValues = Array.CreateInstance(typeof(string), 2);
object a;
object b;
try
System.Threading.Thread.Sleep(1000);
OpcGroupNames.SyncRead((short)OPCDataSource.OPCCache, 1, ref ItemServerHandles, out ItemServerReadValues, out ItemServerErrors, out a, out b);
throw ex.InnerException;
var value = ItemServerReadValues.GetValue(1);
opcServer.OPCGroups.RemoveAll();
opcServer.Disconnect();
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
225
Trying to use the APPICOM OPC server that comes with Bradcommunications APPLICOM Card for wornderware. When I "browse" the OPC tags I get Group...
4,314
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,706
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,822
Hi, Has anyone communicated Rexroth IndtaControl PLC CML40.2 with over OPC or MODBUS TCP/IP? I am working on a Project for MES where i need to...
1,593
