OPC for Rslogix 500 Emulate
andijkt75
Jun 2007
Jakarta
Dear friends,
I am trying to use Rslogix 500 Emulate to emulate PLC in my PC, and I try to use Infilink software for HMI.
Is that possible to combine them? What OPC should I use? RSLinx or KEP?
I tried both but still can not work.
Thx
Hi Andijkt
Using RsLinx you can connect RsEmulate to Infilink scada.
STEP 1. Create the topic in RsLinx
STEP 2. Cconfigure Tags in Infilink for OPC server RsLinx
If you want to use RSLinx, the "free" RSLinx "Lite" won't work. You'll need one of the higher versions of linx.
Doesn't matter which version of Linx it is. It must be a "licensed" version (Not the free RSLinx "Lite") for this to work.
opc for rs emulate except rslinx
Is there any opc other than rslinx that can connect to rs emulate 500?
RSLinx Classic is the only OPC Server that can connect to RSEmulate 500.
You must have at least the "OEM Single Node" license for RSLinx Classic.
I think that "RSLinx Single node" is OK, if andijkt75 just have to connect to that single simulated SLC500. It is half the price of RSLinx OEM.
Df1
hi guys, does anyone knows how to connect rslogix 500 emulator to Kepserver? My case is like this, I have :
- rslogix 500 configuration/ladder file from my site PLC
- config file from site kepserver for the PLC
- config file from site infilink for the PLC
I am trying to simulate the process in my PC by using those files. fyi, the system does not use OPC but use DDE (Kep). I see that the kepserver is configured with DF1 driver (so i think in site the kep always get data from DF1 - RS232 port). While my emulate doesn't be associated with any port (am i right?).
So, is there possible to simulate those system?
Rgds
Alright, here is what I know. In the lab we are building a new OSIsoft PI system and need to inject some real life data into the machines for...
11,741
Hi Guys, I need to modify an existing application (RSLogix 500 on a Micrologix 1500). The Micrologix is linked ethernet to a PanelView via a...
6,436
Hi, I want ot take data from a RSlogix 500(Table structure) using the DDE/OPC topic definition and want to display data in Wonderware using...
6,769
Hi all, I’m an electrical engineering student doing my final year project which involves PLC work. The course is mostly focused on the power...
2,697
is there any free ware OPC data collector to get the data from controllogix 5000??
4,031
