OPC Link Configuration Help
Ones_Zeros
Feb 2014
at work
367
Hello,
I have not configured a new OPC Link before & was needing some help please.We have TDS running that is polling Totalflow meters.
I was needing to setup OPC Link to communicate with Wonderware.
Here is a screen shot of what I have configured so far, but it doesn't work
I get a "configuration error" when I select "Data Monitor" in OPC.
How can i check this to see were I have made my mistake?
The Data Monitor is polling my meter, but displays a configuration error.
I appreciate any help
Dear All, In our system, we have two S7 400 PLC's one for each application..I have Intouch at PC station end...The steps I am following to view...
3,790
Dear Friends; I copy the link of Tag value and paste it as a link in Excel but Cell shows #REF The images are attached where i am wrong...
776
Hi forum! I am using a unit called IBH Link UA which have a built-in soft Siemens S7-PLC, OPC server and OPC client function. I have mostly used...
2,046
Has anyone had any success linking data from global tags in a 5069 (L306ERM) to RSLinx using an DDE/OPC Topic? I've done this hundreds of times...
2,625
Hi; I had designed an HMI in RS View32 Works and an SLC-5/05 had connected with that HMI via direct driver. Now as per requirement, i need to...
2,799
