nickegeson
Hi forum! I am using a unit called IBH Link UA which have a built-in soft Siemens S7-PLC, OPC server and OPC client function. I have mostly used the PUT/GET function in S7 for communication using the soft PLC but now I need to use the OPC client function reading from another server which in this case is bulit in inside a S7-1500 PLC.
So, the problem is I can only connect to the server using RSA-SHA256 security policy + username and password. But no matter what I do I get “BadCertificateUriInvalid (0x80170000)” using the certificate supplied from the server. The server is set to allow all client connections.
For testing purpose I tried the same way of connecting using Kepware as a client and the same certificate without any issues.
I also tested using different security policies connecting the IBH Link UA as a client to Kepware with the same result, meaning it is giving the same fault. If I set security policy to "none" for Kepware-IBH Link connection everything is working fine.
I also tried manipulated/created new certificates using the UA configuration tool.
I have contacted the supplier of the IBH Link UA but so far haven´t got the answers I need.
So, does anyone out here have any experience with these IBH units or OPC certificate issues in general, maybe particularly for this fault?
