OPC Problems - long/detailed - need help
Lakee911
May 2006
Columbus, OH
98
Hi All,
I'm trying to use OpenOPC (and like everything else under the sun) to connect to an Iconics HMI OPC Server. It works fine from my Laptop (Running WinXP), but it doesn't work from my client's computer. I've tried XP, Vista and Server 2008R2. The server is what I actualy need to run on the PC.
This is the command the run on my laptop:
Code:
C:\Documents and Settings\User>opc.exe -m dcom -h op2hmiprimary -s {0E8B028E-8569-43F3-AE5E-50072BD2ED1E} -o csv -r STMOA47.IO_Unit_1.Top.AIN.AIN_1_Scaled_Value
This returns
STMOA47.IO_Unit_1.Top.AIN.AIN_1_Scaled_Value,2.0167,Good,09/12/11 16:19:48
When I run it on any of my client's PCs I get the following:
Connect to OPC server '{0E8B028E-8569-43F3-AE5E-50072BD2ED1E}' on 'op2hmiprimary' failed - Connect: Unspecified error (Unspecified error)
Now, the OPC server (op2hmiprimary) is not in a domain, but some of my clients PCs are and my laptop is as well.
When I run the command and it fails, I'm getting the following in the Event Log
The launch and activation security descriptor for the COM Server application with CLSID
{13486D44-4821-11D2-A494-3CB306C10000}
is invalid. It contains Access Control Entries with permissions that are invalid. The requested action was therefore not performed. This security permission can be corrected using the Component Services administrative tool.
Windows Firewall is off on all of the computers, anyone can telnet to any machine port 135 just fine. I've tried setting up IPC$ connections prior, nothing helps.
I've only been able to get one program to work and that's Advosol OPCDA.NET Client Component Evaluation OPC DA V2 Test Client.
So, I'm at a super big loss here for what to do. I've spent so much time and I have really run out of options. I'd appreciate any help. Any ideas?????
Thanks!!!
Hello,
As soon as you connect from one PC to another DCOM gets involved and if I had to guess it is a DCOM setting that is getting in your way.
I don't think it is DCOm as I can make some connections, but I won't rule it out. Got any specfic suggestions on what to look at?
How does IIS apply?
Thanks.
Hello,
>I don't think it is DCOM as I can make some connections
A classic symptom of DCOM issues. ;)
I can tell you how to make it work with PeakHMI. Search the web for OPC and DCOM and you will find data.
Great... I have done lots of that searching but nothing clear cut on the client end. I don:t have access to the server, but if I can tell them what to change they will.
Jason
Right the issue is going to be on the server side.
PM me your email and I will send you a short doc for PeakHMI and maybe you can apply it to your OPC server program.
And remember when you make a change to a DCOM setting you need to restart the computer for the change to fully apply.
The software: RSLogix5000 + Graphworx32 by Iconics + Iconics Unified Data Browser + Applicom OPC Server I need to have my HMI software...
3,178
I downloaded the demo software and install it on my desktop and my laptop computer. I built a small Quick Client with four Data words and five...
7,632
Does anyone knows this message on the tag database : "Server doesn't support browsing namespace." specifically when the node name is an OPC...
5,642
anonymous
A
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
237
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
219
