OPC server and DCOM
hello
Guest
H
can some one tell me what is an OPC server and how distributed communication play a role in this
thanks
IMHO, it all started with the Clipboard :nodi:
Since MS was walking away from DOS they came up with the famous "Clipboard". We could Cut and Paste many things (Read Object) from within a Windows compatible application.
The evolution of this nice feature led us to OLE. Its an evoluted Cut&Paste function. Its Object Linking and Embeding.
More than just Pasting the Object from XCell into Words, some dynamics where introduced. If the Object where to change at the source, it would also change at the destination. Again a nice thing.
Between application ? Could use DDE!
OLE could be could also be called COM since COM ... Components Object Models was little different from OLE.
DCOM (D is for Distributed) was often called "Network OLE"
Ho ya! COM is also Activex!
OPC on the other hand (OLE for Process Control) was definatly developed for the industries. A task force set some standards to promote inter-brand comunication of Data.
DCOM could be said to be the infrastructure that transport OPC Data between applications on different computers. It is not essential. It is very often used.
Normaly we don't have to go into details when we setup some netwroked systems. We have to "configure" them nodes. That is unless you intend to write some VB OPC clients and need to know.
What will the next best thing be from our friends at MS?
Could we call OPC "Clipboard" versions 10.0 ?
NAAAA! They will come up with a nicer name.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
237
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
133
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
184
Hello everyone, I wanted to share my findings with getting the new OPC UA server working (I think you might be interested in this JeremyM :lolis:)...
2,035
I have a Win10 64 bit host for my OPC DA server, which is Indusoft (Studio,Scada.OPC.3). Locally OPC works, Matrikon OPC Explorer. On my Win7...
1,179
