OPC Server clone
Tomo453
Mar 2018
Mt. Juliet, TN
83
Has anyone run an OPC server / client as a virtual machine. I have a recipe manager and operational historian running on a desktop at the Main Operators station on an automation line. My fear is hardware failure, and to reduce downtime in this event, I thought I would make a virtual machine of this desktop and run it on another computer that may or may not have the same OS. Any foreseeable drawbacks or tips? Getting all the recipe values into all the various PLC's and drives manually would be a tedious chore for sure. Thanks in advance.
As others have said, should be fine, especially if it's over Ethernet.
However, something to consider: Normally VMs can share the Ethernet interfaces, but depending how much bandwidth you're currently using, you might need to take that into account. If you put 5 VMs on the same HW that each were expecting to use 25mbps on the 100mbps card, it won't work as expected.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
279
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
144
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
199
Hello everyone, I wanted to share my findings with getting the new OPC UA server working (I think you might be interested in this JeremyM :lolis:)...
2,177
I have a Win10 64 bit host for my OPC DA server, which is Indusoft (Studio,Scada.OPC.3). Locally OPC works, Matrikon OPC Explorer. On my Win7...
1,206
