Opc Server with excel
Amphytrion78
Guest
A
hey
i want to connect my opc server with excel
what should i enter as item path in the alias configuration
thanks
I'm not sure Excel can read OPC tags. But, it can read DDE.
If you're using RSLinx (I'm guessing this because you said "alias")the formula is:
=RSLINX|DDETOPIC!ADDRESS
You'll need to configure the DDETOPIC in RSLinx. Alias topics are used to create alternate paths to the same processor. You'd use them if you had two ethernet cards in a rack, or a backup COM port, etc.
AK
Hello all, I'm using Ignition as the HMI for a project. I do not have physical access to a PLC to download our project on to for development...
17
4,415
Hello All, I know it is possibile to access data from a PLC directly to excel using a OPC link through RSLinx...
1,762
Hello, I am looking for help writing to PLC tags from Excel. I am using Factory Talk Gateway as an OPC server and Excel VBA to write out to an...
3,107
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
243
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
133
