Opening file created with studio500 on RSLogix5000
If your Logix5000 version 19 is licensed, you can download and install whichever version of Studio5000 you need to support the program you are trying to open. Your existing "activation" should be valid for Studio5000
Basically, RSLogix5000 and Studio5000 are the same animal, although there are some subtle differences such as the name, and the default application storage locations.
I'm sure you are aware that you need to install all software versions to support your hardware...
Hi
You could post it here and someone might save it has a .5lk and then send it back to you .
If you open the file you will see where the version is, change this and them import it to you version
Donnchadh
Right click on your ACD file and select "Open With"
Click on Notepad and select "Open"
At the top you will see the version history
Last line in this section will tell the revision that you must have to open it.
Install it and you can edit the file
This file was generated by the RSLogix 5000 software.
DO NOT ALTER THIS FILE
2010-09-17 06:29:50.166: File Creation
2010-09-17 06:29:52.923: Saved - V19.00.00/3432.000
2010-09-17 06:29:56.417: Saved - V19.00.00/3432.000
2010-09-17 06:29:58.462: Saved - V19.00.00/3432.000
2010-09-17 06:29:59.666: Saved - V19.00.00/3432.000
2010-09-17 06:32:03.486: Saved - V19.00.00/3432.000
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
103
Hello, I have a CNG compressor that is run by a PLC. I tried to get team viewer on it to be able to view it remotely, I accidently disabled the...
123
Hello Rockwell Experts! An integrator sent me an ACD file of a draft program for an upcoming machine installation for me to review. They've been...
988
Respected Members; I installed Studio 5000 version 30 and RSLOGIX version 13 to 20 on my machine. I restore my computer system image two days...
1,345
Good day all. We just had a machine retrofit with new controls which included a new PV file. I was told I would be given the development file but...
1,396
