Opinions wanted: Logix & Point I/O use.
Jeev
May 2008
Brisbane
743
Recently I've had someone who's asked me "Why don't we use a ControlLogix or a CompactLogix controller, but instead of using the larger backplane and I/O cards, use Point I/O over Ethernet/IP?". I then rattled off a few pros and cons not entirely liking the idea, but I'm interested to see what others think.
Anyone?
Jeev.
We use Control Logix with a wide variety of remote IO types on a combination of ControlNet, DeviceNet and EthernetIP. We very rarely use any 1756 IO at all and the idea of having all of your IO in the same location as the PLC now seems completely alien to me. Discrete and Analogue IO is normally FlexIO but much of the IO we used to use has been absorbed into network connections to intelligent motor control gear (AB E3's and VFD's), smart instruments and other controllers.
Andybr
For low density remote locations, we do utilize the Point IO. For our higher density remote locations, we use the 1756 IO. We do not use EthernetIP for our communications media - we use ControlNet. Only due to our own infrastructure requirements. But I do not see any issue other than the hardening of your particular Ethernet system for IO.
With the Automation Directs Open Source Arduino Compatible PLC and the Open plc Project, plus all the Raspberry Pi HMI's, what are your opinions...
4,348
I'm refactoring a task handling system that creates transport tasks to shuttle wagons in a material handling system. My environment is S7...
3,176
I am looking for some opinions on TSSA inspection. I am working on some assembly equipment that will be going in to Canada. This equipment will be...
2,515
This question got buried in another related thread so I thought I would repost it. No I did not search first because if I had additional questions...
6,206
Designing a COPY or COP command should be easy, but there are so many things to consider. We have decided to add a COPY command even though it is...
11,631
