OptoIsolator Relays
S7Guy
Nov 2003
Dayton, Ohio
1,250
Ok, I've got an upcoming project where I'm interfacing to some third party equipment. Much of it will be a discrete interface, and I am looking at needing about 120 optoisolator relays. The input from the will be 24v from the machines, and will switch 24v to my PLC input cards.
What I'm wondering is whether I can eliminate the relays altogther. At $30 each, it's not a huge deal, but if I can safely drop them, why not? I'm using Siemens 32pt digital input cards; do they offer some degree of isolation? What should I look for?
The project has a relatively small margin, but of course I don't want to have problems either. Thoughts?
I think I can safely say ALL PLC digital input cards have optoisolators.
Make sure the Zero Reference (input common) comes from the other machine.
Hey Everybody I am looking for a ac input optoisolator circuit. I am using this for an input to a 12vdc operated PLC. I need to be able to...
2,289
I tried the click plus PLC to send emails today but could not get it to work over my network. I need a mass alert when a temperature reaches a...
415
Hey guys, the scenario is: I have already completed the drawing package for my system utilizing an A-B 440R-N23126 (Minotaur) safety relay. SoS...
159
I'd like to talk this through a little: Relays are regularly used for PLC outputs, regardless of a need for signal conversion. But what about...
960
Good Evening , I should know more about Solid State Relays . I have a system with 8) 120 vac Vibrators . These Solid State Relays have...
24
2,091
