Schematic for using an optoisolator
Lionel
Jan 2003
Hey Everybody
I am looking for a ac input optoisolator circuit. I am using this for an input to a 12vdc operated PLC. I need to be able to detect the presents of a ac input. This will then allow the Plc to perform
the logic depending the presents of the voltage. I am using a NTE3089
and really have no idea how to configure the output. I have a 27k resistor to the input of the device to drop the voltage from 120vac to about 60vac. Can anyone help?
Lionel
Sinking or sourcing input?... :confused:
A more inportant question that I have...
How do you plan to mount this????? Sorry, but I'm not a big fan of the "home brew" method. Using an IC might be good for learning, but not good in an industrial environment.
Have a look at something like THIS. A G4IAC15 in a socket will be simple to wire, with many less headaches in the future.
Hey, wait a minute... Is there a reason why you can't just use a 120VAC relay?...
Cheap and easy... Can't get much simpler than that... :rolleyes:
beerchug
-Eric
Optoisolator
Eric
This device will be in a good inviroment (motorhome).I would rather use electronic devices instead of relays. Once I get it designed then I will worry about it looking home made. Different monitoring devices use this theory. I just can't find any schematics on this type circuit.
Lionel
If you are really into kludging, then a resistor and diode may be all that's required.
Most PLC 12VDC input circuits already employ an opto coupler, and if this is the case then you may get away with simply adding an external resistor to ensure current is limited to the original spec, plus add a diode to prevent reversal of polarity. Obviously it's going to be easier if you have a schematic of the PLC's input circuit, but 10k resistor and IN4004 would likely be in the ballpark. The resultant signal will now be 1/2 wave and would require some filtering, but often this is already dealt with on the 5V side of the coupler. Worst case just add 10 mf or so to filter things out.
Don't recommend trying this unless you clearly understand the existing circuit and the effects these additions will have. A floating DC supply won't do here as you'll need a reference to the AC side.
I'd just buy a relay myself.........
Hello, fairly new to plcs I’m tasked with installing a PE to a micrologix1200, in the attached picture I/14 is the PE I’m installing it’s going to...
960
This is my first IO-Link project. I am having trouble figuring out how to draw this in ACAD-E. How to show the system as well as the wiring to...
1,765
There are so many different ways to tackle the first sheet of the schematics. I've seen some people with a cover sheet, followed by several...
2,626
Which Style to you expect to see on a drawing? Which style to you prefer? Keep in mind this being used on very large projects Style 1 Style 2
21
6,767
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,131
