OT: Alternating relay 24vdc coil
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
I have a need for an alternating or ratcheting relay with 24vdc coil. Each time the coil fires, the relay needs to switch states. I found one made by Time Mark (261DX-24), but my purchasing agent asked for a different make . . . apparently it's a very long lead item.
This thing needs to be as compact as possible to fit inside an OEM enclosure, and the contacts are used for low power 24vdc solenoid coils, so about any contact rating should work.
Thanks,
Paul
Omron and many other manufactures have latching relays if you only want 2 positions - latch - unlatch. They are pretty inexpensive. For 2 positions there is generally no need for a ratchet relay.
Bob, I think Okie needs a device with an output contact that changes from OFF to ON to OFF, repeating each time the 24 VDC coil is triggered by an input switch. The alternating function could be wired with 2 or more relays (the old "toggle" function, but he would like it in one small neat package).
This is what he needs, except a brand that his purchasing agent will accept. Someone buy him one of these and ship it! (GIT, Paul needs your help!)
http://www.time-mark.com/Alternating-Relays-Model-261.aspx?cp=0&ps=2&CategoryID=6
Paul, contact this Time Mark sales representative:
WAYNE G. PARKER CO.
Jenks, OK
tel 918 299-5026
fax 918 299-6747
[email protected]
www.waynegparker.com
Thanks for the help, guys. It appears we have the TimeMark unit ordered now, my parts guy just didn't look in the right spot for a local distributor.
Lancie's description above is correct. An OEM built a machine for us but sort screwed up one part of the design a little bit and the alternating relay would simplify their design and eliminate a couple of failure prone parts.
Their design uses a single output from a proprietary controller to operate one of two solenoids. They did this by wiring the single output through two proximity switches and then to each coil. Only one switch should ever be on at a time. The switches are 12mm with a 2mm sensing distance and mounted in a poor spot, so they have sheared off the ends of the switches about 6 times in 3 years. The OEM doesn't seem willing to change their software to use two outputs (they have 6 spares) so the alternating relay thing is a band-aid, but for this small bleeding wound, it's not a terrible place to apply one.
I’m stuck and I need your help. I am a very inexperienced programmer and my current job requires a basic understanding of programming RsLogix. I...
9,979
Today I was making an online edit to a 5/40 Series E Rev K.2 with about 14% free memory. I was removing one branch in a large rung. Accept...
3,176
I have 2 pumps not alternating at a lift station. When im at the panel and use the test switches to initiate the pumps,it alternates in the PLC...
22
5,848
Hello I have been thinking in some way to operate 3 pumps in the same way (I have schneider modicon m340 PLC): -the pumps feed a tank. - As...
1,885
Hi Everyone, trying to get an alternating output to work. Read through the forums on flip flop, toggle, etc. Found this site...
4,226
