Alternating system of 3 pumps
ayoubil
Aug 2018
spain
Hello
I have been thinking in some way to operate 3 pumps in the same way (I have schneider modicon m340 PLC):
-the pumps feed a tank.
- As maximum it can work only 2 pumps of the 3 available.
-The operation of the pumps has to alternate depends on the operating time
I tried to compare the running time of the 3 pumps by timer but I could not. Can you have any idea for it?
Thank you
It’s generally accepted in full triplex pumping systems that in the long run, pump wear and tear evens out without needing to get overly aggressive about trying to force it to happen. A simple way of dealing with it, mimicking the way it is done by humans with simple triplex panels, is to keep a running log of run time and start counts, then if one pump deviates more than about 10% higher than the average, take it out of rotation for a while.
Today I was making an online edit to a 5/40 Series E Rev K.2 with about 14% free memory. I was removing one branch in a large rung. Accept...
3,176
I have 2 pumps not alternating at a lift station. When im at the panel and use the test switches to initiate the pumps,it alternates in the PLC...
22
5,851
Hi Everyone, trying to get an alternating output to work. Read through the forums on flip flop, toggle, etc. Found this site...
4,226
Hi I'm kinda new at PLC programming sorta teaching myself. I need to alternate between two motors run one till satisfied the when it calls again...
1,524
I have 2 motors on a VFD that are alternating on/off when started (HOA switch in auto) after an ESD. When the operator toggles the HOA switch from...
1,941
