OT - calculate torque output
katratzi
Mar 2005
210
I have motor/mechanical variable speed pulley/gearbox drive system that I do not know how to calculate the output torque capability of. The system consists of 1700 rpm 12.5kw motor, attached to a Lenze variable speed pulley unit, which the output of is connected to a gearbox with a 31.5 ratio. The Lenze unit has a stated ratio of 20:1, which I am assuming is the max since it is a mechanical variable speed device. Lenze identifies this device as a "Simplabelt compact unit".
I do not know how to calculate output torque of unit like this. Can anyone show me a formula or a good website that has information on this?
thanks for link, Nathan. I think the losses you mentioned are the key, especially at the Lenze variable speed pulley unit. Because the torque output capability of the system seems way too high for a 50mm shaft to withstand. This may be ok though, because the roll that the 50mm shaft is attached to is turning a conveyor belt that is tensioned between this roll and another roll at the other end, so maybe (hopefully) it would slip instead of twisting the shaft.
This old Lenze unit is gone, it definitely needs replacing with new motor/ gear unit at this point.
As a general rule, a variable pitch pulley system such as the Lenze unit you mention is limited to a maximum torque multiplier of 2 due to the tendency of the belt to slip at torque levels higher than that.
yeah, that would explain a lot. i never considered belt slippage at pulley system, seems obvious now that you point it out. a mechanical idjit, i am.
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,063
Good morning, I have a question. I don't know much about ST yet I would like to calculate the average number of products per hour. how do I do...
22
2,983
Can someone help me with this? I'm no good at SCL - virtually everything I've done so far has been ladder logic. The return value from the...
1,119
I want to calculate the energy consumed from instantaneous power. Can this be done using the TOT block with timebase set to Hour?
701
Hi everyone, I have to calculate the length in millimeters of a glass that enters a transport (I don't know the speed yet) through a barrier...
3,474
