OT : Compu-Aire Sensor
Mad_Poet
Feb 2017
Virginia
375
Dear Sirs,
I have an old Compu-aire air conditioning unit that has a little sensor
board in it that measures the temperature and humidity from which a computer board decides what to turn on or off to control the server
rooms temperature etc.
The board has a wire coming off for the temperature, and a wire coming off it
for the humidity.
The temperature wire reads 22 VDC . . . and when I flip the fluke meter to AC
volts it gives me 20 Vac.
The humidity reads about 5.6 Vdc . . or 32 Vac.
A similar unit that is running good has similar readings.
Can anyone explain to me why there is both ac and dc signal voltage levels
in this thing?
And, the little sensor board is powered by 24 Vac.
Poet.
hello! i have a problem with a belt weighting system integrator is compu-m (milltronics) and 2 units with 2 cells each wich i guessed it is a...
4,509
Hi all, On behalf of my colleague, I would like to invite you to participate in a short questionnaire about industrial automation. The...
1,173
I have a dataword ,each bit is actually an alarm, No i have to program a condition that shut down the installation when more than two bits are set...
42
8,771
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
113
