OT: Crimp tool for wiremount mini sockets
the_msp
May 2008
Northern Ireland
1,271
I crimped a cable with this (attached) connector back a few years, but the company it was going into had the tool. Could someone please advise what I need?
I've done quite a few of these. I usually get it started back and forth with a plastic screwdriver handle until the points are through then squeeze the parts together with pliers. If you're looking for a real tool, search for "IDC ribbon crimp tool."
I think they are called 'ribbon cable insulation displacement connector tool' or 'idc tool'. Do a web search for 'ribbon cable idc tool', you can find them at RS. You do need the grip of a weight lifter to make them work, which is why I also go for the bench vice option :)
Yeah I was considering a vice or whack it with a hammer as a last resort :)
1. Always use the right tool for the job
2. A hammer is always the right tool for the job
3. You can use almost anything as a hammer
I have to make up some cables with 9-pin D-sub connectors on one end. I've done this in the past with solder cup connectors, but I don't want to...
4,065
Can somebody share the AutroSafe configuration Tool C4.11.4 Thank you
117
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
140
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
360
Hello everyone, I'm having trouble downloading a file to a omron nt11 PT. I am able to upload from 2 other PT's but am unable to download...
225
