OT: Cryogenic fluid pumping, expert needed
Ken Moore
May 2004
North, West, South Carolina
3,476
Not a controls question, but this board has such a huge mixture of skills, hopefully someone can assist.
We have an existing cryogenic ethylene pumping system that we are having difficulties with, and are looking to bring in some outside expertise. Does anyone know of a firm or person specializing in this field? If so, can you provide contact information. I suspect experience in any cryogenic application would suffice, not just ethylene, I would guess anyone familiar with cryogenic nitrogen experience would be able to help out as well.
We're also looking for flammable gas compression consultants.
Thanks.
Ken,
You might try the Eng-Tips forum, I searched on their site for "Cryogenic fluid pumping" and came up with quite a few hits.
You could also post there and will probably get more responses than on PLCS.net as they have a lot of traffic on some topics.
Mike
I work around Cyrogenic Air Seperation Plants. I'm into PLCs & Process Analysers, not a pump expert - however I know a few engineers here who may be able to help. I've programmed some PLC controls for cryo pumps - is it a control/logic issue or a mechanical issue. What sort of problems are you having.
Okay, before we get started, a DP transmitter is my only option, tank contains liquid ethylene, cannot use a radar or ultra sonic, load cells are...
5,210
this is an off subject question, but Im sure ur a bunch of clever chaps and wouldn´t mind helping how can I calculate the denisty of liquid...
2,106
Hi all What system (best) would you guys out there recommend to measure the level of liquid nitrogen at -182ºC.... in a storage tank... Besides...
6,350
Good Evening Everyone, I am attempting to monitor the level of hydraulic fluid in a tank. The tank is 50 gallons. For insurance purposes we need...
4,200
Hello: We use submersible pressure sensor in oil tanks to monitor the level in the tank. We also have a routine the will estimate the oil...
1,405
