OT - file undelete utility needed
James Mcquade
Oct 2007
Nashville, Tennessee area
3,683
Everyone,
I was at a customers site and placed several files on a jump drive. I then went to the office and placed the files on our server as per our procedure. No problem, we used those files on the server with no issues and I then deleted those files from the jump drive. The drive crashed before the backup could run.
Last night our hard drive failed so I called the customer and explained what happened since we are on very good terms.
I just heard from the customer and his drive has the blue screen of death when he started the pc.
Can anyone recommend a file undelete utility that will work on jump drives that they have used?
The files can be recreated from scratch if necessary, but will set the project back 1-2 months.
thanks in advance,
james
If the customers PC "only" has a BSOD, then he can mount it as an external/extra drive on another PC and access the files from there. The OS might be bad, but the rest of the files are often still good.
I use this to recover flash drives plus it's free. I have used it to save a couple bad situations for customers.
http://www.easeus.com/resource/drive/usb-flash-drive.htm
James if I understand correctly you placed the files on your server and lost a hard drive before your nightly backup?
1. You may want to think about a hot sync for your server in addition to your backup
2. A single HD failure on a server should not lose data if your RAID is setup correctly. maybe something to look into.
All the PLC & HMI files I have stored on the network drive I also make a copy & keep because I got bit by a drive failure & when IT restored it the backup they used was about 2 months old. Everything I added or changed since then was lost.
No more trusting IT to do what they're supposed to do, I rely on myself now.
I'll second that .....
Sounds like your IT people are doing data integrity work of which the do not have the required skills.
Having backup is only one part of the puzzle. You should also have real time replication onsite and fast replication offsite in addition to incremental and full backup strategies both onsite and offsite. Cloud technology is a good way to implement this.
A plan like i have given you above inspires confidence and is what you IT team should be striving to accomplish.
Losing critical customer date / intellectual property that takes that much time, effort and money to create is inexcusable.
I would not have much faith in them either if these results are a product of their efforts
Sounds like your IT people are doing data integrity work of which the do not have the required skills.... Cloud technology is a good way to implement this....
I agree, that's why I save my copies in my OneDrive folder, and it's automatically downloaded to my home computer & my laptop as soon as I save any change.
(also, for some unknown reason OneDrive gets through the firewall & I can transfer any file between home & work that the firewall would report to IT or prevent.)
P.S. - guess what my opinion of IT guys are?
Whenever I see someone looking for an "undelete" function, it makes me cringe. Straight away you know that something has gone very badly wrong :unsure:
Hope you get it working James!
Interesting looking software too, PBuchanan...think I might have to download that one and have a play with it!
We were in the process of upgrading our server to a newer system and as you said, something went very wrong.
We ended up buying Norton utilities in hopes of restoring the drives.
thanks for your replies.
james
james
Ach... Norton? Seriously?
All "Norton" products ceased to be viable when Peter Norton sold out to Symantec.
There is virtually nothing you can't already do with Windows itself that the utilities act as a clunky front end for.
Cleanroom House - costs @ 1000.00, but usually recovers most of it. This will work for the Hard drive, I think they take the hard drive apart. Not sure about the thumb drive.
rdrast,
I hate to admit it, you were right.
Norton utilities is worthless, absolutely worthless !!
the software found several files and recovered them, but the files are corrupt.
Most of the files were never discovered and there is no directory structure.
regards,
james
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
74
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
76
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
136
I just converted an existing application from RSView32 to FactoryTalkView SE. In RSView32, the Datalog was made in a *.DBF file. There was...
71
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
70
