g.mccormick
I'm doing some work preparing for adding some concrete patios. Im running conduit underground in preperation of a future garage. I'm also going to go ahead and drive a second ground rod into the ground just cause. For the second ground rod, do I have to bond it to the first (I'm digging but having a hard time actually finding it). Can I bond the two grounds in the main disconnect/service entrance ground bar? Future work will probably have me installing a generator transfer switch. This is where the grounds would bond. Right now, I will probably not connect this ground to anything, just get it above concrete level.
