rsdoran
I agree it is about energy BUT there are rules (laws) to how energy is created and/or transfered.
Like I said, there are some differences in how Peter has to control hydraulics with motion control but it still does not change the laws/physics involved.
Y'all take something that is fairly simple and try to make it sound complicated. There is always pressure on everything, it is called gravity. In a system that pumps water, especially upward, into a tank there will be some added pressure from the weight of the water, it is called head pressure.
If you take that tank of water when filled and no water flowing and you read pressure at the bottom end of the tank it will show a static pressure. P = h x sg/2.31.
IF you pump water into that tank while removing it at the same rate of flow the pressure will drop because some of the pressure is converted to flow (fluid velocity).
As stated it is about energy, whether a hand pump or driven by an electric motor a pump directly transfers the fluid from one place to another with enough force to overcome opposition...whether that be head, gravity, a load, or a system designed to offer opposition to create a higher pressure.
I dislike (or disagree) with the concept of blocking off either inlet or outlet, when that is done there can be no transfer of energy i.e. the pump can not do what it is designed to do; which is to push/pull a fluid from one place to another.
In a basic hydraulic system you normally work within a specific flow rate at a designated pressure. As mentioned above when you have flow you may have a decrease in pressure, that is where accumulators come in. They are pre-charged for a designated pressure, so they fill when the system has developed its operating pressure then discharge when the system may have a pressure drop due to fluid velocity (flow).
In the end it still comes down to a pump provides flow with enough force to overcome gravity and/or head pressure but the system may need to transfer more energy then that therefore the system has to be designed to resist the flow so the fluid can develop pressure so it can store/transfer more of the primary energy it is converting.
