allscott
- Join Date
- Jul 2004
- Posts
- 1,332
First of all I agree with Peter and Alaric, the energy is what matters not the chicken and egg thing however;
Let's break down the whole pressure vs flow debate into bubba terms. Picture a run of the mill 1750 era piston pump. As the piston retracts gravity (or suction) fills the cylinder cavity with water or oil. As the piston extends the fluid is pushed out. If this piston is open to the world no pressure is developed, just flow.
If you bolt a head on this pump all of a sudden there is a resistance to the flow of the oil out of the cylinder and thus pressure develops. How much pressure the pump can develop is related to the area of the piston and the amount of torque that the rod driving the piston can develop.
If when dead headed the prime mover of the pump can develop more torque and hence stress on the mechanicals of the pump than it can withstand, something breaks. This is why relief valves were invented.
Hydraulics systems aren't developed to introduce a resistance to flow in order to create pressure. It is the actuator of the system that inroduces the resistance that happens to make the pressure, ie: the cylinder that has to move a mass or the hydraulic motor that needs torque to turn something. Everything else in the system is just a parasitic loss.
So yes, pumps create flow not pressure
nuff said.
nuff said.
